17152 Discussions
Intel Core 2 Duo Processor P7450 2.13GHz SLGF7
I search Spec code for this processor on the search area : Intel Core 2 Duo Processor P7450 2.13GHz SLGF7
I can't find any informations about this Step code : SLGF7
I find only SLB54 Spec and SLB56 is Retired and Discontinued : http://ark.intel.com/Product.aspx?id=36734&processor=P7450&spec-codes=SLB54,SLB56 http://ark.intel.com/Product.aspx?id=36734&processor=P7450&spec-codes=SLB54,SLB56
The SLGF7 is retired and discontinued ?
Can i use on my motherboard a SLB54 processor Spec code or not ?
The Memory controller hub is Intel® 82PM45 Memory Controller Hub : http://ark.intel.com/Product.aspx?id=35135 http://ark.intel.com/Product.aspx?id=35135
Think you very much for your answer
Regards.
Adolfo_S_Intel2
You need to contact the motherboard or laptop manufacturer and ask them for a list of fully supported processors for your motherboard.
Keep in mind that the compatibility between the processor and the motherboard is determined by the motherboard manufacturer, not by the processor manufacturer.
