Hello, i have installed everything but i can't pass the test
Chipset : Intel� 9 Series Chipset - Z97Chipset Stepping : A0
No device connected to PCI Express Port 0
No device connected to PCI Express Port 1
1 device connected to PCI Express Port 4
1 : Killer e2200 Gigabit Ethernet Controller (NDIS 6.30)
1 device connected to PCI Express Port 5
1 : Sound Blaster Audio Controller
1 device connected to PCI Express Port 7
1 : ASMedia XHCI 1.0 Controller
--- Error while retrieving SATA Device Information from OS ---
..Platform Controller Hub Test Failed..
Platform Controller Hub Test Failed. Error while retrieving SATA Device Information from OS
- Tags:
- Intel® PCH Chipsets
Hello Bl4ckD3m0n,
This is not a very common issue but please try these steps:
- Reinstall the motherboard Chipset Driver.
- Reinstall Intel® Management Driver.
- Update motherboard BIOS.
After these steps, run the Intel® Processor Diagnostic Tool again and if issue persists contact our support Center.
Here is our contact information:
http://www.intel.com/p/en_US/support/contactsupport http://www.intel.com/p/en_US/support/contactsupport
Kevin M
Hello Kevin,
thank you for the answer,sadly i still can't pass the test, so i contacted intel support center.
I reinstalled intel rapid storage and i can pass the pch test now
