17160 Discussions
Intel S3200SHV - E7600
Does anybody know if this processor is running with the board?
It´s actually new, but the E7500 is supported and the stepping is the same, also the CPUID String (1067Ah)
Chris
Hi there,
All tested processor for this motherboard S3200SH can be found on the following list.
Link: http://www.intel.com/support/motherboards/server/S3200SH/sb/CS-028293.htm
Please note, it's better to check the processor by their SL number as well. If you cannot find any matching SL number for the processor from the list, this means that it not supported.
From the list it can be noticed that the E7600 is not on the list, hence it is not currently supported on this board.
Hope this is useful to you.
Cheers
