16975 Discussions
Intel XTU signature validation failed. I9 14900k
Roots
Currently having an issue where when I attempt to open up Intel XTU, I get a message stating the following:
"Permission Denied: XTU signature validation failed. One or more files does not have a valid signature!"
Things I have done so far:
1. Stopped the services.
2. Compeletly uninstalled XTU, deleted all files related to XTU and wiped the registry for XTU, then rebooted. (Multiple times...)
3. Checked previous posts with the same issue which stated to do the above ^.
4. Verified certificates are up to date.
Not really sure where to go from here. The program worked fine before, however, I recently RMA'd my 14900k and received a new one that is currently in my computer. After replacing the previous 14900k, the program no longer works. All of my settings are identical to the previous CPU in BIOS as I had saved a profile.
ArielP_Intel
Hello Roots,
I’m truly sorry to hear that you’re encountering an error message when trying to open Intel® XTU. I understand you’ve already tried several steps and recently replaced your processor.
To help resolve the issue, I’ve put together the following recommendations:
  1. Reboot your system and try rerunning the Intel® XTU installer.
  2. Uninstall Intel® XTU by following the steps outlined in the How to Uninstall the Intel® Extreme Tuning Utility (Intel® XTU) article.
  3. Download and install the latest version of Intel® XTU.
  4. Ensure that you have the latest BIOS version installed. You may want to contact your board manufacturer to confirm this.
  5. Admin permissions required: Manually delete the c:\Program Files\Intel\Intel(R) Extreme Tuning Utility directory. Be cautious not to delete any other program folders.
  6. If the issue persists, consider updating Windows or performing a fresh Windows installation.
Please let me know if any of these steps work for you. I look forward to hearing from you soon!
Ariel P.
Roots
Followed all of your suggestions, including fresh windows installation:
- BIOS is updated.
- Latest version of XTU is downloaded.
- Used the uninstall article you linked.
After doing so I still get the same error when trying to open XTU.
ArielP_Intel
Hello Roots,
Thank you for keeping me updated on this. I understand that the previous recommendations haven't resolved the issue yet. Let me check this internally for further steps we can take. Your patience is greatly appreciated, and I’ll keep you posted with any updates.
Ariel P.
ArielP_Intel
Hello Roots,
I just received word from my team and we're here to help! Could you please confirm if Intel XTU version 7.14 worked with your previous CPU or if this is your first time using it? If you've followed the troubleshooting steps outlined (How to Uninstall the Intel® Extreme Tuning Utility (Intel® XTU)) and still see a "Permission Denied" error? Please share your system info and log files from C:\ProgramData\Intel\Intel Extreme Tuning Utility\Logs.
Remember to remove all XTU services, delete Intel Telemetry, and reboot. Also, note that C:\Program Files\Intel and C:\ProgramData\Intel are separate folders.
Please let us know how it goes. Looking forward to your response!
Ariel P.
JohnM_Intel
Hello Roots,
I hope you had the chance to review the information I posted. Please let me know at your earliest convenience so that we can determine the best course of action to efficiently resolve this matter.
John Sergio M.
Banshee0926
I have the same problem.It used to worked but i can't use it now.
My cpu is 13th Gen Intel(R) Core(TM)i9-13900K.
Roots
Unfortunatley I never figured it out. Still can't use XTU to this day, wish I could fix it.
