17154 Discussions
Intel i7 13k power issues
Leog98
I have an Intel I7-13k and the power consumption is at 450W from the bios settings. I have tried to update the bios to the lates version that intel has put out and i have no results. I have an MSI Z690 Edge Board with 850W power supply. I am running into power issues where the PC will randomly shut off and blue screen. I have updated the bios to the lates version that intel says, will fix the issue. But when i updated it. I still have problems turning on my PC. There is a CPU fault LED that is indicated on the board. If I restart the PC, its like cold starting a CUMMINS in the winter time at 4 degrees. Please send help or something where I can fix this issue.
I can provide a detailed list of the specs of the PC
Please send help, this has been going on for a couple years!!!!!!!!!!
StanleyB_Intel
Hello Leog98,
Thank you for posting in our Community. To help me narrow down the cause and find a solution, could you please provide a bit more information:
  • Since this is a 13th Gen processor, would you be able to tell me the specific model number?
  • Besides the BIOS update to the latest version, what additional troubleshooting steps have you tried?
  • May I know the date of purchase for the processor? Your retailer can often provide immediate replacement or refund options if the unit was purchased less than 30 days.
  • Any physical damage present on the unit? Please note that the warranty will be voided if there are damages due to external factors
  • Have you tried overclocking the processor? Please note that if the system was overclocked (manually or using Intel® Speed Optimizer or AI Assist or other methods), including voltage/ frequency beyond the processor supported specifications, your processor voids warranty.
Once I have this information, I will be glad to guide you on the best next steps and determine what can be handled. If you have any questions, please let us know.
Stanley B.
BrenzL_Intel
Hello Leog98,
Brenz L.
StanleyB_Intel
Hello Leog98,
I have not heard back from you so I will close this inquiry. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Stanley B.
