17152 Discussions
New PC freeze all the time
MLepa
Hello every one.
I bought components to build a new PC. No problem for build it but when I power it on, it freezes all the time.
Sometime it freezes before MB bip, sometimes I can go into the BIOS and it freezes when I navigate into it.
I tried install an OS but I can't. PC freezes during files loading or reboots just after the load.
This is parts of the computer :
MB : http://www.newegg.ca/Product/Product.aspx?Item=N82E16813138395 http://www.newegg.ca/Product/Product.aspx?Item=N82E16813138395
CPU : http://www.newegg.ca/Product/Product.aspx?Item=N82E16819116942 http://www.newegg.ca/Product/Product.aspx?Item=N82E16819116942
GPU : http://www.newegg.com/Product/Product.aspx?Item=N82E16814127784 http://www.newegg.com/Product/Product.aspx?Item=N82E16814127784
HDD : http://www.newegg.ca/Product/Product.aspx?Item=N82E16822136795 http://www.newegg.ca/Product/Product.aspx?Item=N82E16822136795
Memory : http://www.newegg.ca/Product/Product.aspx?Item=N82E16820231445 http://www.newegg.ca/Product/Product.aspx?Item=N82E16820231445
PSU : http://www.newegg.ca/Product/Product.aspx?Item=N82E16817139050 http://www.newegg.ca/Product/Product.aspx?Item=N82E16817139050
WL card : http://www.newegg.ca/Product/Product.aspx?Item=9SIA4FT2600220 TP-LINK TL-WN881ND Wireless N300 PCI Express Adapter, 300Mbps, w/WPS Button, IEEE 802.1b/g/n, 64/128 bit WEP, WPA/WPA2 -…
Then I unplugged GPU, HDD, WL card. I tried with another memory sticks, power supply, keyboard, screen
I tried out of case
The motherboard was replaced but the problem is still the same.
I made some tests with memtest, cpu burn-in and IPDT. Here are the results :
memtest :
cpu burn-in :
ipdt :
Any ideas about this weird problem ?
Thank you.
Jose_H_Intel1
Hello Mike63, you may replace the Intel® processor with the seller or through your local Intel support team.
http://www.intel.com/p/en_US/support/contactsupport Contact Support
