17158 Discussions
No new device drivers were found Windows 10 Setup
RyanSGaming
Hey Intel community, I'm having trouble installing Windows 10 on my system.
Specs: (I know it's old, it's temporary)
Intel DQ57TM motherboard
Intel Core i7-860
14Gb DDR3 (1x8gb, 3x2gb)
Radeon HD 5570 (Used to be gtx 1060 6gb, swapped out to try and fix)
I can't install Windows because it says "A media driver your computer needs is missing". I've tried to install the RSVT drivers, but that doesn't seem to work.
Thank you guys
Labels (2)
MACM
Hi RyanSGaming,
Greetings of the day.
Hope you are doing well.
Thank you for sharing the details.
We will go ahead and transfer this case to correct team, and they will reach out to you shortly.
Mohammed Ali CM
Intel Customer Support
AlHill
All the drivers you need for W10 are in the box.  Of course, your processor is not supported by W10.
Ok, remove  the amd card, and use a nvidia card, and install W10.  I seriously doubt that an amd card will run on this board.
Was your nvidia card bad?
Also, what is your bios rev?
[This is the dawning of the age of Colossus, where peace is compulsory, freedom is forbidden, and man’s greatest achievement is man’s greatest mistake.]
