16897 Discussions
P530最新显卡驱动安装后出现显示器亮度下降
AChou2
P530最新显卡驱动(24.20.100.6094)安装后出现显示器DP亮度下降
AlHill
Run this utility and attach the results:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility Download Intel® System Support Utility for Windows*
One of the Intel support agents will be able to assist you.
Doc
AChou2
我通过你发送的链接发现一些信息,但是看不到有起作用的配置文件。
以下是安装驱动后的信息截图:
AChou2
我的显示器仅支持DP1.1版本。
Alex Chou你好,
请提供以下信息:
主板模型。
处理器型号。
使用的驱动程序的链接。
已执行的故障排除步骤。
Eduardo_B
AChou2
主板型号:X11SSZ-F
处理器:Processor: Intel(R) Xeon(R) CPU E3-1275 v5 @ 3.60GHz
驱动程序链接:https://downloadmirror.intel.com/27892/a08/win64_24.20.100.6194.exe https://downloadmirror.intel.com/27892/a08/win64_24.20.100.6194.exe
已执行的故障排除步骤:
1.卸载24.20.100.6194;
2.回退驱动程序版本至10.18.15.4278,亮度正常;
3.再次安装24.20.100.6194,亮度明显下降。
Thank you very much for the information provided, Alex_chou.
By checking into your https://www.supermicro.com/products/motherboard/Xeon/C236_C232/X11SSZ-F.cfm motherboard's specifications, I can see that there are not available downloads for the Intel® HD Graphics controller, instead, the Aspeed AST2400/AST2500 Graphic Driver is the only download available for your mainboard (cf. https://www.supermicro.com/support/resources/resource_drivers.cfm Drivers & Utilities for X11SSZ-F).
It seems that the graphics engine on your motherboard is managed by the Aspeed AST2400 controller. Please get in touch withhttps://www.supermicro.com/support/index.cfm Supermicro Support to double check if there is a way to change that or if the only controller that can be used is the Aspeed one.
Antony S.
Hello, Alex_chou.
I would like to know if you still need assistance. If so, do not hesitate to reply back.
Antony S.
