17153 Discussions
Please Help! Can't uninstall, can't finish installing Turbo Boost Monitor
I downloaded the latest Turbo Boost Technology Monitor and installed it.
The monitor window popped up for one second, then my (Win7 x64 Ent) computer immediately BSOD'd (0x7e).
Now it appears I'm stuck:
  • The program doesn't run
  • If I attempt to uninstall OR reuse the Setup.exe installer, I get a message complaining that the temporary *.msi file (long name in c:\users\\AppData\Local\Temp) is missing
So I cannot re-install and cannot uninstall.
Is there information available on, or ideally a tool to automate, completely removing this software from my computer without using the installer/uninstaller?
Thanks much,
Pete
DArce
Valued Contributor III
Could you please specify the version number of the Turbo Boost Technology Monitor that you installed?
Also, please provide the dxdiag report from your system. Go get the report, go to the Start menu > type dxdiag > Enter > click on save all this information.
