16981 Discussions
Possible GPU Problem installing windows 7 I7 2006K
Hello all!
I have been trying install windows 7 64bits in my pc using video onboard, because when i try use the offboard card the systems reboot.
after install the Intel Driver video, windows doens't boot correctly! freeze on the boot(windows logo).
I already tried use ASUS Bios in default mode and others ways..
My system:
OS: Windows 7 64 bits professional
CPU: I7 2600k
MOBO: ASUS P8Z68-LX
POWER SUPPLY: CORSAIR TX650
RAM: 16 GB
GRAPHIC CARD: XFX ONE HD 5450
- Could it be a GPU problem?
I tested the CPU in another board and the same problem happened..
Anybody knows what can be happening?
regards,
Pachecux
Jose_H_Intel1
It seems to be not related to graphics because you get issues with the graphics card or the processor's graphics as well. Still, you may try testing the system in safe mode or with a different graphics driver version but it is also a good idea to test the memory and verify if it is compatible.
