17151 Discussions
Prime95 errors with i5 661
I just set up a new system and ran prime95 to test for stability. I almost immediately got errors.
Is it possible that it could be the cpu as the RAM is stable (as tested by 20 rounds of memtest86 resulting in 0 errors)
Info:
My motherboard is GA-H55-USB3,
RAM is OCZ Platinum (OCZ3P1333LV4GK)
According to OCZ the RAM should be set at 7-7-7-20 with the mem multipier to 10X and the mem voltage at 1.65V
Note: I am only using one 2GB stick of RAM as the other stick is faulty.
Is there some other setting I should adjust in the BIOS to compensate for these changes? ie. Vcore?
Hello;
In order to test if the processor is actually the problem I recommend to test it on a different system, also you can try to different memory on the desktop board
