16777 Discussions
Problem with Q9550
Motherboard does not start up when my Q9550 pluget in. It all started when I try to plug in a new video card.
No ram. No Video Card. Only CPU and MB. No post sounds.
http://www.youtube.com/watch?v=lYqYZUZIgXg&context=C33140d8ADOEgsToPDskLY5XF4IJ9DNY5jgbL9swof http://www.youtube.com/watch?v=lYqYZUZIgXg&context=C33140d8ADOEgsToPDskLY5XF4IJ9DNY5jgbL9swof
CPU was tested at 4 different motherboards. Same result.
What could it be? He died?
Sry 4 bad English =D
RGiff
Honored Contributor I
what board are you using , the Q9550 has a 1333 FSB , if your board has a Lower FSB it will not work .
Gigabyte EP45 extreme FSB 1600
This may be due to memory?
When memory is not plugged in should be heard any POST sounds?
RGiff
with no ram installed you should hear 3 beeps .
RGiff
When the Q9550 was working did you do any overclocking >??
RGiff
Q9550 is a good CPU but not for overclocking easy to burn up specialy with high volts.
