16898 Discussions
Processador Intel core i9 13900k
Jeferson195405
A versão da bios 0x12F versão final quando sai para placas mãe MPG Z690 FORCE WIFI até agora tá na versão beta mais não sei se devo instalar pois não tenho certeza se essa versão beta ela está instável estou aguardando a versão final do Update de bios pra minha placa mãe MPG Z690 FORCE WIFI
VonM_Intel
Hi Jeferson195405,
Thank you for posting in our Community, and the Intel® Core™ i9-13900K paired with the MPG Z690 FORCE WIFI is a strong combo. Regarding the BIOS version 0x12F, it's great that you're being cautious. If the version currently available is labeled beta, it's typically meant for testing and early feedback, and may not be fully optimized or stable for all use cases. While beta BIOS updates can sometimes improve support for newer CPUs or features, they can also introduce instability or bugs, especially if you're not experiencing any issues with your current setup.
If your system is currently stable and performing well, it's often best to wait for the final (non-beta) release, unless the beta BIOS specifically addresses a critical bug or compatibility issue you're facing.
To better assist you, could you help us with a few quick details?
  • What BIOS version is currently installed on your motherboard?
  • Are you currently experiencing any issues with system stability, boot, or performance that you hope the new BIOS will fix?
  • Is there a specific feature in the 0x12F beta BIOS that you need (e.g., improved CPU microcode, memory compatibility, etc.)?
  • Are you using any overclocking settings or advanced memory profiles (XMP)? Some beta BIOS versions may reset or impact tuning settings.
  • Are you running Windows 10, 11, or planning to dual-boot another OS (e.g., Linux)? Some BIOS updates impact boot compatibility.
Have a nice day!
Von M.
VonM_Intel
Hello Jeferson195405,
Von M.
VonM_Intel
I have not heard back from you, so I will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Von M.
