QX9300 vs Q9100 ?
Hi! Is anyone know what is the main difference between QX9300 and Q9100 except the frequency and unlocked for over-clocking? I mean what the X means? Is it only unlocked OC feature?
Adolfo_S_Intel2
The "X" means that it is an extreme processor, so it is an unlocked processor.
To compare the features of both processors please check this link:
http://ark.intel.com/compare/36727,37033 http://ark.intel.com/compare/36727,37033
Adolfo_S_Intel2
I knew X means Extreme and I already compared them before from the same link. What I realy wanted to ask is if I am not interested with OC and don't care about the frequency difference between QX9300 and Q9100 is there any other important difference which is not mentioned in the compare page? Which choise would be wiser, QX9300 or Q9100? Cause the prices quite different.
Adolfo_S_Intel2
The only differences between both processors are the ones showing on the link provided on previous thread.
The differences are very small, so you might not notice the performance difference between both processors.
If you are still not sure about what processor to buy, I would suggest then contacting any Authorized Intel® Distributor so they can provide you further buying recommendations.
You can find a list of Authorized Intel® Distributors at:
http://www.intel.com/cd/channel/reseller/asmo-na/eng/227304.htm http://www.intel.com/cd/channel/reseller/asmo-na/eng/227304.htm
If you are not located in North America, please check this link:
http://premierlocator.intel.com/Default.aspx http://premierlocator.intel.com/Default.aspx
No I definetly will buy Q9100 but some other things are confusing me? In the market espacially China, there is a lot of Q9200 QAVR or QAJF. I checked intel's web page there is no such CPU. What is the reality about that CPU?
Adolfo_S_Intel2
Since we do not have any processor with that model number, it means this could be a counterfeit processor, please check only with Authorized Intel® Distributors on your location.
If you are not in North America, please check this link to find local Authorized Intel® Distributors:
