I've a notebook with a Intel® Core™2 Duo Processor P7450 (3M Cache, 2.13 MHz, 1066 MHz FSB). Under stress the processor hit a temperature of 75°C. Is this a bad temperature for this processor? It could damage it after a long period? Thanks
The maximum recommended temperature for this processor is 90 degrees Celsius as showing at:
http://processorfinder.intel.com/details.aspx?sSpec=SLB56
So 75 degrees Celsius is under the thermal specifications for this processor, in other words as long as the processor does not reach above 90 degrees Celsius the processor will be running fine.
