16888 Discussions
Question about gpu clock drop on Rtx 2080 Ti with 9900k.
SLitw
Hello.
I have a question. I am using Rtx 2080 Ti Waterforce and 9900K and Corsair 850RmX. ALL stock,no oc.
Drivers up to date,Windows 10 1903v.
Few days ago ,when i run Fire Strike GPU test 1 on loop, i saw a clock dip from 1980mhz to 1570mhz for 1ms. GPU LOAD not changed,it was 96%. Only gpu clock dip for a 1ms.
I checked in logs,and during that gpu power drop to 58%.
screen:
https://i.postimg.cc/XqSFQWQ1/ui1.jpg
I cant reproduce this.
Second.
Yesterday i run TimeSpy looped gpu test 1. Clock during 40 minutes was 1920-1970mhz with random power usage. But one time it dropped to 1800mhz. Is this normal? Screens:
screen
1920mhz:
https://i.postimg.cc/RZPzz144/t1.jpg
screen
And that 1800mhz for 1ms:
https://i.postimg.cc/cJmtWb66/t2.jpg
Its faulty GPU ?? But In games i dont had any once such drops in clock.
David_V_Intel
Hello SLitw,
Thank you for posting on the Intel ® communities.
In this case, since you are having problems or inquiry related to the dedicated video card, please post the question on the Nvidia* support forums:
https://www.nvidia.com/en-us/geforce/forums/discover/
* Please be aware that the content on that site is not controlled by Intel*. This information is offered for your convenience and should not be viewed as an endorsement by Intel* for the merchants or services offered there. *
Or else, try contacting Nvidia* support directly so they can have a look at your configuration and the informaiton you have related to the clock drop.
David V
A Contingent Worker at Intel
