Speed Step
PieJea
Boa tarde,
Preciso de ajuda para parar o SpeedStep, tenho tido muitos atrasos por conta da minha frequência GHz que me impede de trabalhar em um ritmo constante. A velocidade base da minha CPU é de 2,10GHz, mas em qualquer situação roda em 0,48GHz.
Estou ciente dos riscos e que não é recomendado remover o SpeedStep, mas é algo que eu preciso para o momento.
Maria_R_Intel
Hello PieJea,
Thank you for posting on the Intel* Community.
Our support is only provided in English. We may not be able to translate screenshots attached to the thread. To better assist you, we use a translation tool, keep in mind that the information may not be 100% accurate.
To better assist you and have more information about the system you're using, please run the below tool and provide us with the report generated:
Intel® System Support Utility (Intel® SSU)
  • Intel® SSU Download
  • Open the application and click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
  • Click on the menu where it says "Summary" to change to "Detailed View".
  • To save your scan, click on "Next", then "Save".
Maria R.
Maria_R_Intel
Hello PieJea,
Let me know if you need more assistance.
Maria R.
Maria_R_Intel
Hello PieJea,
We have not heard back from you, so we will close this thread. If you need any additional information, please submit a new question as this thread will no longer being monitored.
Maria R.
