TP2.0 MODULE
Louie1
IS IT STILL REQIURED TO FIT THIS TO THE MOTHERBOARD WHEN USING I5 CPU
pressed_for_time
Valued Contributor II
Yes, the ASROCK PROH610M-EDDR4 motherboard has a modern Intel chipset that includes the platform firmware option in the BIOS. It meets all the security requirements of Windows 11 and no separate TPM 2.0 module needed.
pressed_for_time
TPM 2.0 (Trusted Platform Module 2.0) relies on the hardware to support it which is (1) a motherboard that supports TPM 2.0 and (2) a  compatible CPU. Both are required for TPM 2.0 to function correctly.
Some Intel motherboards require a discrete module to be installed, others allow a choice between a platform firmware option (no module needed) or a fitted module. See screenshot below from an ASUS B760 motherboard that has both options.
Louie1
Thanks for the info  My MOTHER BOARD IWISH TO BUY  is  a  ASROCK PROH610M-EDDR4 THEY CLAIM THAT NO TPM2.0 IS REQUIRE TO RUN WIN 11
pressed_for_time
Louie1
