Weird temp spikes on my CPU.
Idles around 40-45 but every time i open an app it spikes to 80 sometimes 90c and falls back down.
Sometimes without doing anything i get temp spikes randomly. tested with 2 different AIO same result. Temps under constant load seems to be fine. but random tasks in windows causes concerning spikes.
What can be done?
Might need to re-paste your CPU...
I suspect the pre applied thermal paste on the AIO is enough
Hi smawpE,
Thank you for posting in the community,
You can also try following the steps for Overheating Symptoms for Intel Boxed Processors:
Overheating Symptoms and Troubleshooting for Intel® Boxed...
For us to further understand the issue, may I know if the processor is working fine before?
May I know when the issue started?
Are there any changes on the system before you encounter this issue?
Did you overclock the processor (Note: we do not recommend overclocking the processor, overclocking the processor may void the warranty validation of your CPU)?
Earl E.
It started as soon as I booted up my system. No OC has been done. No changes in system, only updated bios to try to combat the issue but no success. Tried a new AIO same issue. Tried different ram same issue.
The CPU is very unstable and has random spikes.
Hi smawpE,
You can try to test the processor using Intel Processor Diagnostic Tool.
The Intel® Processor Diagnostic Tool Overview, Download, and...
May I know the exact make and model of your motherboard?
What BIOS version are you currently on?
Earl E.
I have tried but nothing came up
I have NZXT N7 Z790 BIOS version 13.01
Hi smawpE,
Thank you for sharing this information with us.
I'll be sending you an email, kindly check your inbox.
Earl E.
