Turbo Boost BSOD
MVasq3
Principiante
5.672 Visualizações
Random BSOD when 100% Processing Usage on Power Plan and activation of turbo boost. With battery and power cable (laptop)
10 Respostas
MVasq3
Principiante
3.568 Visualizações
Test Results from Processor Check Utility
Amy_C_Intel1
Funcionário
3.568 Visualizações
Hello MVasq3, Thank you for posting on the Intel® Communities. When did the issue start? Have you checked with your computer manufacturer regarding this issue? Amy C Intel Customer Support Technician Under Contract to Intel Corporation
MVasq3
Principiante
3.568 Visualizações
I think it started with new windows update or something. I looked and there is no turbo boost program installed on the PC shall that be the problem or maybe power issues? I contact MSI but the PC is out of warranty. And they told me to send it but I can't be without it. ​
Amy_C_Intel1
Funcionário
3.568 Visualizações
If possible, roll back the Windows 10 update. The Intel® Turbo Boost Technology is an automatic feature, there is no program or application to set it. I recommend you to check with MSI for all the updates for your computer model. For more information visit: https://www.intel.com/content/www/us/en/architecture-and-technology/turbo-boost/turbo-boost-technology.html Amy C Intel Customer Support Technician Under Contract to Intel Corporation
MVasq3
Principiante
3.568 Visualizações
I tried with 1708 and it gives me blue screen also with 100% usage. Can be a power problem with the motherboard or the cpu? the cpu tests are on 99%, i cant do them on 100% because as soon as i change to a 100% power plan i got BSOD.
Amy_C_Intel1
Funcionário
3.567 Visualizações
I can't confirm if this is a problem with the motherboard, since it's a third-party computer only MSI can confirm if there is hardware failure. Based on your Intel® Processor Diagnostic Tool results, I can confirm that there are no issues with the processor and since the issue started after a Windows 10 update, the issue seems to be there. You could also check with MSI if a BIOS update can help in this case Amy C Intel Customer Support Technician Under Contract to Intel Corporation
MVasq3
Principiante
3.567 Visualizações
But after that update, i formated the pc with all different versions with USB to fully format the system and the BSOD persisted, even with previous versions then the "last working one". All BIOS and EC Firmware updated to the last version offered in their website. Anyway i will try to contact them for further investigation. Thanks for the help.
Regards Manuel Vasques
Amy_C_Intel1
Funcionário
3.567 Visualizações
Sure, and you are welcome to share their response here. Amy C Intel Customer Support Technician Under Contract to Intel Corporation
MVasq3
Principiante
3.568 Visualizações
Hello, again, from the information that i provide here and provide to them also, the MSI team conclude that it may have a high probability of being the CPU/Chipset on the board. So it may be chipset.
Amy_C_Intel1
Funcionário
3.568 Visualizações
Thanks for sharing that. Amy C Intel Customer Support Technician Under Contract to Intel Corporation
Responder
