16964 Discussions
We need proof to show to the customer why we should quote generation 2 instead of Generation 1 below example: =>Intel Xeon-Silver 4110 replace by Intel Xeon-Silver 4208
RZeyd
please share with us PDF
David_V_Intel
Hello RZeyd,
Thank you for posting on the Intel ® Processors Community.
I understand that you are looking for proof to show why you should use Generation 2 Xeon* processors instead of Generation one. This is something that should be analyzed depending on the use as well as the technologies needed and the features.
To elaborate, parting from your example, the Intel ® Xeon Silver 4110 has slightly less turbo boost speed than the Intel ® Xeon Silver 4208; also, the amount of memory supported by the latter is larger than the first one. You can have more information in the link below where you can find a comparison between both processors:
Intel ® Xeon processors comparison
In a general sense, some generation 2 Xeon* processors give you the ability to use Intel® Optane™ DC Persistent Memory Module. For more information, you can check the link below which lists the different Generation 2 Xeon* Scalable processors:
Intel ® Xeon Generation 2 Scalable processors
I hope this helps.
David V
A Contingent Worker at Intel
Emeth_O_Intel
Hello RZeyd,
I would like to know if you still need help with this information?
If so, please do not hesitate and let me know and I will be more than happy to assist you.
Emeth O.
Emeth_O_Intel
Due to the fact that we have not seen any recent activity on this thread.
I am going to proceed and close it. If you have more questions in the future do not hesitate and contact us back and we will be more than happy to assist you.
Emeth O.
