16565 Discussions
Weird i9 14900K P-Core #4/5 temperatures
phaze
hey guys,
I built my PC a month ago, and been monitoring the temps for a while now and now I see that P-core #4 and #5 have like around 15 celsius degree higher than other P-Cores.
One thing to keep in mind, when I was installing my AIO LS720S Zero Dark, my finger came a little bit on the side of the thermal paste and slightly pushed it from its place (Not fully removed)
I even tried using Gigabyte F6d "Intel Default Settings" BIOS update and still P-core #4 fluctuates.
Can someone tell me what could be causing it or if its normal?, like it reaches high Maximums but the average is very close to other normal P-cores.
For example when I run Apex Legends, my P-Core #4 goes to 90  while other cores are like 10-15 degress less than the P core #4 or 5 or smth.
I Run "Ultimate performance power plan"
Also 1 more thing, Sometimes on HWINFO, I see Core thermal throttling on Maximum "YES" even though None of the cores reached TjMax, shown in a picture.
Full PC Specs:
i9 14900K
Z790 AORUS ELITE X AX
Gigabyte 4070 Super Gaming OC
T-Force Delta 32GB 7200MHz CL34
Lian Li 216 case.
Mike_Intel
Hello phaze,
For us to further check this, please help provide the following details:
1. Do you notice this behavior while idle, gaming, or browsing?
2. Have you experienced any crashes or errors (BSOD)?
3. Are you using the Intel® Extreme Memory Profile (Intel® XMP)?
4. Can you share the temperature reading inside the BIOS?
Michael L.
phaze
Hey Michael,
1. I noticed this a few times when PC was idle (Windows could've possibly done something)
- When browsing temperature is around 68-75
- When gaming Temp is around 85-90
2. No, never experienced any crashes.
3. Yes 7200Mhz T-Force Delta 32GB (2x16) CL34
4. In BIOS the CPU shows between 32-36
I have High Performance Power plan right now instead of Ultimate performance.
Also, when I launch Apex Legends from Steam, sometimes the maximum reaches 95-98, sometimes 78-85. but then temp goes back to normal afterwards.
phaze
Hey,
I did the stress test by using the tool you provided, It passed and everything is fine.
But again I check HWmonitor, temps are fine for Stress test, but it shows that core thermal throttling on Maximum coloumn is "YES"
even though nothing reached TjMax.
phaze
I attached here the Test Result Output file.
Mike_Intel
Hello phaze,
Thank you for the update.
Let me gather additional information.
  1. Are you using default settings inside the BIOS?
  2. What is the brand and model of the processor cooling?
  3. Can you run the processor diagnostic tool for us to check the processor. Here is the link:
https://www.intel.com/content/www/us/en/support/articles/000005567/processors.html
Michael L.
phaze
Hey,
1. Yes currently on "Intel Default Settings" BIOS version for Z790 AORUS ELITE X AX (F6d BIOS version)
2. DeepCool LS720S ZERO DARK (360mm)
3. Yeah I will run it and get back to you, hope it doesn't fry haha!
Mike_Intel
Hello phaze,
Intel Processor Diagnostic tool is not a stress test app. It should be safe to run this app to check your processor.
I will wait for your next update.
Michael L.
phaze
Hey,
I replied with the results and attached the results file from the App. and screenshots of the temps.
Mike_Intel
Hello phaze,
Base on the temperature reading inside the BIOS and Processor Diagnostic tool, everything is running fine.
However, I will still have this checked by our Engineers. Kindly help generate the SSU logs of your system as our additional data:
Kindly download the utility here:
https://www.intel.com/content/www/us/en/download/18377/intel-system-support-utility-for-windows.html
Michael L.
phaze
Hey,
I'm looking forward to hearing from you and the Engineering team back, I attached the file in this reply.
Thank you!
Mike_Intel
Hello phaze,
We will do further research on this matter and post the response on this thread once it is available.
Have a fantastic day, and thank you very much for your patience and understanding!
Michael L.
Mike_Intel
Hello phaze,
Thank you for patiently waiting for our update.
Upon checking all the details that you provided, here is our feedback.
Upon reviewing the temperature data, it appears to be within the expected norms, and the Intel Processor Diagnostic Tool (IPDT) has yielded a PASS result. If you need further information regarding processor temperatures, you may find the articles provided to be quite informative.
And also, we suggest conducting an Intel Extreme Tuning Utility (XTU) test, checking the temperature reading inXTU, and comparing the results with those from Hwinfo64. This comparison is crucial as it helps ensure that the overall temperature remains within the acceptable range, thereby preventing any potential issues.
Lastly, we want to assure that if the overall temperature remains within the specified limits the system should operate without any complications.
Michael L.
Mike_Intel
Hello phaze,
Michael L.
phaze
Hey,
Yeah, I think I will get used to it sometimes rapidly reaching around 95 and goes back to normal, so it should be fine as in the links you provided.
So I guess its a normal thing specially for i9 14900K, as long as the averages are around 60s after around an hour of gaming, so my CPU should be fine and no thermal issues nor bad AIO contact issue.
Thank you so much
Mike_Intel
Hello phaze,
Thank you for understanding.
You can just continue to monitor the processor for performance issue.
As for the temperature, this is normal.
We will close this inquiry for now. .
Michael L.
