17162 Discussions
What does MCi_STATUS MSR = 0x00000000BE000000000000000100110B and MCi_STATUS MSR = 0x00000000BE000000000000000100117B mean?
I have encountered two BSODs (bug check 0x124) on two different devices using Intel Celeron 3765U @ 1.9 GHz.
Additional parameters provided by the bug check:
1. 0, 0xFFFFFA800532A038, 0xBE000000, 0x100110B
2. 0, 0xFFFFFA800530C038, 0xBE000000, 0x100117B
Have created a support ticket at Microsoft and support engineer asked me to check contents of the MCI_STATUS MSR with Intel.
So here it is:
1. MCi_STATUS MSR = 0x00000000BE000000000000000100110B
2. MCi_STATUS MSR = 0x00000000BE000000000000000100117B
Additionally a support engineer at Intel already opened the case# 02812568.
Is it possible to gain more information from the contents of the MCI_STATUS MSR?
Thank you very much in advance.
BR,
Matthias
Hello matgst,
Thank you for contacting the Intel community.
In order for you to get the proper support for this embedded device, you will need to post it at the following link:
https://embedded.communities.intel.com/community/en https://embedded.communities.intel.com/community/en
On the right you will see the option to start a discussion.
Ivan U.
Hello matgst,
Ivan U.
Ok, thanks.
Posted it here:
https://embedded.communities.intel.com/message/20324# 20324 What does MCi_STATUS MSR = 0x00000000BE00000000... |Embedded Community
BR
Matthias
Thank you for the information, that's the place where you will get the information you need.
Ivan U.
