16842 Discussions
Wrong Output when Input size Grows
aasda38
I am now optimizing a simple a program. Element of a and b are made sure to be from 0 to 8, so in my opitimization I turned them from int to short.
void ans(int n, const int *a, const int *b, int *answer) { for (int k = 0; k < n; k++) for (int i = 0; i < n - k; ++i) answer[k] += a[i + k] * b[i]; }
But I found the output is correct when input size is less than 25k, but being wrong when size exceeds this number and the wrong number of value is exactly (total input size -25k).
And here is what I have done with AVX2 and openmp.
#include <stdio.h> #include <stdlib.h> #include <immintrin.h> #include <emmintrin.h> #include <smmintrin.h> #include <omp.h> #include <string.h> #include <malloc.h> static short n_zero = 0; static int MAX_CORE = omp_get_max_threads();   void calc(int n, const int *a, const int *b, int *c) { #pragma omp parallel for schedule(dynamic) for (int k = 0; k < n; k++) { short *new_a =(short*)alloca(sizeof(short)*16); short *new_b = (short*)alloca(sizeof(short)*16);   {   __m256i partial_sums = _mm256_set1_epi16(n_zero);   for (int i = 0; i < (n - k) / 16 * 16; i += 16) {   for (int j = 0; j < 16; j++) { new_a[j] = a[i+j+k]; new_b[j] = b[i+j]; } __m256i vec_a_1 = _mm256_loadu_si256((__m256i *)(new_a )); __m256i vec_b_1 = _mm256_loadu_si256((__m256i *)(new_b ));   __m256i partial_pd = _mm256_mullo_epi16(vec_a_1, vec_b_1); partial_sums = _mm256_add_epi16(partial_pd, partial_sums); }   short arr[] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}; _mm256_storeu_si256(((__m256i *)arr), partial_sums); for (int i = 0; i < 16; i++) { c[k] += arr[i]; }   for (int i = (n - k) / 16 * 16 + k; i < (n); i++) { c[k] += a[i] * b[i - k]; } } } }
And here is the main program to test them:
#include <chrono> #include <cstring> #include <iostream> #include <ctime> extern void calc(int, const int *, const int *, int *);   extern void ans(int, const int *, const int *, int *);   int main() { std::ios_base::sync_with_stdio(false); int n; int flag = 0; int ff=0; std::cout << "Enter n:"; std::cin >> n; int *a = new int[n]; int *b = new int[n]; int *c = new int[n]; int *answer = new int[n]; // Initialize the arrays std::memset(a, 0, sizeof(int) * n); std::memset(b, 0, sizeof(int) * n); std::memset(c, 0, sizeof(int) * n); //create random arrry unsigned seed; seed = time(0); srand(seed);   for (int i = 0; i < n; ++i) { a[i] = rand() % 8+1; b[i] = rand() % 8+1; //std::cout << a[i] << "/" << b[i] << "\n"; }   // Start the calculation auto start = std::chrono::high_resolution_clock::now(); calc(n, a, b, c); auto stop = std::chrono::high_resolution_clock::now(); std::chrono::duration<double> diff = stop - start; std::clog << "Time elapsed: " << diff.count() << '\n';   //correctness feedback std::memset(answer, 0, sizeof(int) * n); ans(n, a, b, answer); for (int i = 0; i < n; i++) { if (c[i] != answer[i]) { if(answer[i]<0){ ff+=1; } flag +=1; } } std::cout << "--------correctness feedback--------"<< '\n'; if (flag == 0) { std::cout << "ALL PASS"<< '\n'; } else { std::cout <<ff<<"****"<<flag<<"error detected"<< '\n'; } delete[] a; delete[] b; delete[] c; delete[] answer; return 0; }   void ans(int n, const int *a, const int *b, int *answer) { for (int k = 0; k < n; k++) for (int i = 0; i < n - k; ++i) answer[k] += a[i + k] * b[i]; }
And here is the makefile:
ARCH = native   ifndef DEBUG CXXFLAGS = -march=$(ARCH) -O2 -fopenmp -pthread else CXXFLAGS = -march=$(ARCH) -g -fopenmp -pthread endif   %.o: %.cpp $(CXX) $(CXXFLAGS) $^ -c -o $@   calc: calc.o main.o $(CXX) $(CXXFLAGS) $^ -o $@   clean: $(RM) calc *.o   .PHONY: clean
Maria_R_Intel
Hello aasda38,
Thank you for posting on the Intel* Community Forums.
To better assist you, we will send you a private message to request personal information.
Maria R.
Maria_R_Intel
Hello aasda38,
Were you able to check the previous post and the private message?
Let me know if you need more assistance.
Maria R.
Maria_R_Intel
Hello aasda38,
We have not heard back from you, so we will close this inquiry. If you need further assistance, please post a new question.
Maria R.
