16984 Discussions
X3370 on Intel DG45ID
Hello, good morning, I have a motherboard intel DG45ID which is enabled to use the Intel X3360 processor.
I was looking at the model X3370 and see who has the same basic features (TDP, Bus, Socket) than the X3360.
Can it work in my motherboard although not on the list of supported processors?
Thank you Uzorro.
AlHill
As you already know, the x3370 is not on the list of compatible processors for your board:
http://processormatch.intel.com/Processors/CompatibleProcessors?componentName=DG45ID Compatible Processors
A comparison of the two processors:
http://ark.intel.com/compare/33933,35433 http://ark.intel.com/compare/33933,35433
In my opinion, you do not get that much more by upgrading to an x3370.
Will the x3370 work? It might, might not, might have sporadic errors, or might even damage your board.
Again, in my opinion, if it is not on the list of compatible processors, do not use it.
Also, both the processor and motherboard are well out of support.
Doc
OK, thanks for the opinion.
Uzorro.
Hello:
Thank you very much to Al Hill for the information posted previously.
To Uzorro:
I just wanted to confirm the above information as correct, if the processor is not listed as compatible, in that case we do not recommend to use it.
Any other inquiry, do not hesitate in contact us again.
Alberto
OK, order by Amazon one Q9650.
Thank you.
Hello Uzorro:
You are welcome, perfect, thank you very much for letting us know that information, that processor should work just fine with your board.
Alberto
