16628 Discussions
bio configuration
karpull
I have a mini pc that i purchased, not sure why i tried to make a bio change but I did and can't get it to reset to factory settings.  Need help
model ak3v
apollo lake j3455
version 5.12
uefi 2.5; pi 1.4
any place i can get documentation on default setting.  computer is useless can't get pass bio menu.
thanks
CurtM
I just watched a video that provides a simple solution.  The person seemed quite knowledgeable, but I suggest you check a second source.  There's a small round button battery on the motherboard that enables the CMOS, which stores BIOS settings, to retain the settings when the computer is turned off.
Step 0 - Precaution:  Static can damage internal computer parts.  It's best to do this with hard surfaces (e.g., no carpet).  Touch something metal to ground yourself.  If the computer case is metal, touch it when it is plugged in.
Step 1 - Unplug the computer.  Step 2 - Open the case, find the small round button battery, and remove it.  Step 3 - Wait 10 minutes.  Then, of course, reinstall the battery, close the case, plug it in.
(Disclaimer:  I am not an expert, but I found this solution from other sources as well.  And it sounds reasonable.)
Good luck!  - Curt
n_scott_pearson
You'll have to contact the support people for the system manufacturer. It is their BIOS and only they can help you with this issue.
Sorry,
karpull
CurtM
Good luck!  - Curt
karpull
thanks tried that but couldn't get the motherboard.
karpull
Curt,
Your a peach, I did figure out how to get to the battery to reset bios configuration and I'm back up and running.
Thank you again,
karpull
Jocelyn_Intel
Hello, @karpull
Thank you for posting on the Intel® communities.
I am sorry to hear that you are unable to reset the BIOS settings.
However, as Mr. Scott mentioned, you need to contact the proper support team, your System Manufacturer, as we didn't design their motherboard BIOS or know it works. Please contact the correct support.
We truly hope they can help you with this issue.
Jocelyn M.
Jocelyn_Intel
Hello, @karpull
I am glad to hear that your issue has been solved.
This thread will no longer be monitored, but if you need further assistance, feel free to contact us back and submit a new post.
Have a nice day.
Jocelyn M.
