cpu upgrade question
hello all i have a compaq presario cq56-219wm and the processor is a Intel Celeron 900 @ 2200MHz Processor Socket Type : Socket P (478) i want to upgrade it to a core 2duo but i dont know which one would work , any help would be appreciated thank you.
would this one work in this laptop
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5317060&CatId=1969 Processor ( mobile ) - 1 x Intel Core 2 Quad Q9000 / 2 GHz ( 1066 MHz ) - Socket P 478-pin Micro FCPGA - L2 6 MB ( 2 x 3MB ) - Box at TigerDirect.com
Adolfo_S_Intel2
In order to determine which processors will work on your laptop, you need to contact the laptop manufacturer, so they can provide you a list of tested processors for your laptop system.
Keep in mind that the compatibility between the Intel processors and any laptop system is determined by the laptop manufacturer, not by the processor manufacturer.
