h77 chipset driver
blackraven
dell support states the the intel h77 chipset driver can no longer update i tried to see why and it seems it no longer exsist so what can i use to update this h77 chipset driver with please help on dell xps 8500
AlHill
What needs to be updated?   There is no driver, per se.
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
[Windows 11 is the new Vista]
n_scott_pearson
While you are at it, why don't you explain what your actual problem is. Why do you need to apply updates?
