16897 Discussions
i7 14700k package 100°C
Lex98
Randomly today in games I was getting massive fps drops so I checked hwinfo and my cpu cores and package were hitting 100°C
Took off my cooler and cleaned both cpu and cooler then applied some new paste, load back up and my cpu sits over 89°C idle. AIO pump is definitely working as I can hear it pump around if I put my ear on it, cpu paste is fully spread and my overclock is basic xmp.
Never had an issue until today and nothings changed from what I know
Lex98
Idle temps
n_scott_pearson
You made sure the plugs for the fans and pump are properly inserted into the CPU headers?
You made sure that the block is properly mounted on the processor? Regardless, to check you'll have to remove the block to see if the TIM pattern left on the processor and block looked right and thus will need to re-TIM and mount it again.
(Again) You made sure the plugs for the fans and pump are properly inserted into the CPU headers?
Can you verify that the pump and radiator fans are responding properly (increasing and decreasing with temperature changes)?
Hope this helps,
Lex98
Everything is firmly plugged in to the right headers. AIO is running between 3000-5000 rpm.  Every fan in my pc is set to full speed, I don't have them running at different speeds depending on temperature. Good even spread across of thermal paste on both cpu and the block
Mike_Intel
Hello Lex98,
  1. When did you purchased the processor?
  2. Did you overclock the processor?
  3. What is the brand and model of the motherboard?
  4. Have you tried to update the BIOS of your board?
  5. If yes, please provide the BIOS version.
  6. Have you also tried to load the default BIOS settings?
Michael L.
Lex98
This post can be closed now, It's 100% down to the aio's radiator being blocked and not circulating the coolant resulting in overheating
Mike_Intel
Hello Lex98,
Thank you for the update and I am glad that the issue is now fixed
Since your system is working fine now, I need to close this inquiry.
Michael L.
