17152 Discussions
i7-4790K reaches 100-80 celsius
dpinh2
I have a Intel® Core™ i7-4790K with corsair H100i and it reaches 100-80 celsius when i try to load CPU with prime95
When i try to play lets say "guild wars 2" on the lowest graphics it reaches to 70+ celsius
is it normal or there is a problem with the CPU?
Kevin_M_Intel
Hello Davepinhas,
The temperature your processor is reaching is higher than expected when using the system normally. I recommend you doing some troubleshooting steps mentioned here:
http://www.intel.com/support/processors/sb/cs-029427.htm http://www.intel.com/support/processors/sb/cs-029427.htm
Please note that we are also handling this in a different post so if after doing those steps issue continues, I recommend you posting your issue here:
/thread/54032 https://communities.intel.com/thread/54032
Kevin M
