17153 Discussions
i7 920 CPU BSOD's in Windows 7
After having issues with 5 BSOD's in the last 7 days all around a cpu clock interrupt, and getting nowhere with the Intel tech support people who lay blame with Corsair. I changed my memory to what Intel suggested, and continue to have the BSOD's. The latest is as follows (unable to paste from notepad in here) so this is the summary:
Bugcheck 101, {19, 0, fffff880009b1180, 4}
CLOCK_WATCHDOG_TIMEOUT (101)
An expected clock interrupt was not received on a secondary processor in an MP system within the allocated interval. this indicates that the specified processor is hung and not processing interrupts.
Arguments:
Arg1: 0000000000000019, clock interrupt time out interval in nominal clock ticks.
Arg2: 0000000000000000, 0
Arg3: fffff880009b1180, the PRCB address of the hung processor
Arg4: 0000000000000004, 0
If anyone needs the dump file, leave me ur email addy and i'll send it to ya, as I can't copy and paste it here.
Salem_W_Intel1
Hi!
To begin troubleshooting, I'd recommend the following:
1. Clear the event log in BIOS and load its default settings.
2. Test with the most current BIOS.
Note: If your board's an Intel, please, make sure you refer to the following stie:
http://support.intel.com/support/motherboards/desktop/sb/CS-022312.htm
I have the most current bios 1307 from ASUS. It didn't matter. But it's now a mute point as I had a NB/SB chipset failure last week. I'm starting to wonder i fthat was the root of all my problems. As my system is liquid cooled and the temps were between 65-80 C. ASUS RMA'd the board, so I'll let you know.
