17151 Discussions
i7-975 Standard Heatsink, How Do I Turn The Fan's Blue LED Off?
Any help would be greatly appreciated.
I've got a new i7-975 in an Intel DX58SO motherboard for my HTPC, working a treat but the blue LED for the heatsink fan is on and this shines out the back of the case and is distracting while watching movies at night in the dark. Is there a way that the LED can be disabled so this wouldn't be as frustrating?
I really dont think that there is a way but some cpu coolers are verry good looking and ther dont have leds try buying this one: http://www.newegg.com/Product/Product.aspx?Item=N82E16835200035 http://www.newegg.com/Product/Product.aspx?Item=N82E16835200035
p.s. i just checked the type and it works for that cpu!
Best of luck
Billy Babin
TGree22
I have the Extreme heat sink as well and found the light to be distracting and frankly useless (listen up Intel, if you are going to light it please put a switch on it too). I disassembled mine and unsolder the led's. If you remove the fan from the heat sink there is a bit of plastic tape covering the bottom bearing. Remove the tape and you will find a clip. Using a clip spreader remove the clip and the fan will separate from the windings. Now you can access the led's and remove them.
