Hello Everyone,
I have a 14th generation 13900F processor and additionally MSI MAG CORELIQUID 360R V2 3x120mm liquid cooling. There are 3 stock fans in my case. The game in the screenshot is Cities Skylines 2. I use a 2k 240 hz OLED monitor at the highest settings. Regardless of the game, my processor generally reaches 100 degrees faster. Could there be a problem?
The only other game I've had close to this problem with is RUST,MANOR LORD,WAR THUNDER
My system elements;
CPU : Intel Core i9 13900F
GPU : MSI GeForce RTX 4090 VENTUS 3X E 24G OC 24GB
Ram : GSKILL 64GB (2x32GB) Ripjaws S5 RAM
Motherboard : MSI Z790 GAMING PLUS WIFI 7200MHz(OC)
Psu : XIGMATEK EU MINOTAUR 1000W 80+GOLD
Liquid Cooling : MSI MAG CORELIQUID 360R V2 3x120mm
MSI use a system in the BIOS where you select the motherboard settings by picking box cooler, tower cooler or water cooling. I see you have an AIO liquid cooler and may well have selected the BIOS water cooling option. This option sets the CPU power and current limits to levels that are significantly above the Intel default settings and could explain the CPU temperatures that you are seeing.
To quickly check if that is the case selecting the boxed cooler option will approximate to the Intel default settings. Consider trying this setting to see if it does reduce your CPU temps. If it does a more comprehensive solution is available if you are interested.
Can you please give details about this issue? I need to change my cooler.
Hello Szngl,
Thank you for engaging with one of our community members. How is your system doing so far? Were you able to change your cooling system?
Ramyer M.
Changing the cooling system is a costly solution at the moment, and I think it is sufficient. I think the end result is my processor.
Hello Szngl
I am happy to know that you have not changing your cooling system yet as it is better if we continue investigating the system first before making any changes. For now, please share with us your SSU logs so we can be more familiar with your configuration. By the way, may I please know where you are observing the 100 degrees temperature? Were you able to check if it stays at this temperature for some time? I will be waiting for your reply.
Ramyer M.
Hello Szngl
I am just looking for an update regarding the information we requested. Kindly please let me know about this information so we can identify the next steps that needs to be taken to solve this issue.
Ramyer M.
I will reply to this as soon as possible, sorry for keeping you waiting for approximately 1 week.
Hello Szngl
Thank you for updating us and no worries, I understand that you might be busy. Feel free to update us once you have tried our recommendation. I will be patiently waiting.
Ramyer M.
Hello Szngl
I am just looking for an update regarding the information we have requested. Feel free to reply back to us so we can help you. I will be waiting for your reply.
Ramyer M.
Hi Szngl,
We need to close this thread since we have not gotten a response from you: maybe because you are busy or preoccupied at the moment. We know that this is important for you to get it resolved and it is also equally important for us to give you the right solution; as much as we would like to assist you, we need to close it to attend to other customers.
We hope for your consideration and understanding on this one.
If you need any additional information, please submit a new question as this thread will no longer being monitored.
Thank you for contacting Intel® and have a great week!
Alfred S
