I was looking forward to putting my new laptop into service, it is a MSI Titan GT77 HX 13V. I followed DJI Terra's recommended hardware specs (i9 processor, 64 GB memory, Nvidia 4080 GPU). Once I started processing 2D Ortho maps I noticed the render time was 4 times longer than my old laptop (Dell G15 i7 11th gen, 32 GB memory, Nvidia 3080 GPU). It seems the CPU is throttling down once the process is 50% complete, it is using all cores up to 50% (very fast), then parks all but 6 cores.
Expecting a faulty stick of RAM or processor I decided to benchmark the unit, and it performed well at: 27,177 Cinemark multi core.
MSI has been zero help, they are trying to pass the buck to DJI. I am successfully running the exact same version of the software on 3 other poorly configured laptops comparatively.
ANY help would be greatly appreciated!
Try updating the MSI bios. If you have afterburner, uninstall it and restart.
I appreciate the response, I updated the BIOS to the latest version, and haven't installed Afterburner. This is a very strange situation with this machine, I really like everything about it, except the poor performance with DJI Terra. I operate a drone agriculture company and we need a heavy lifting mobile machine to crank out HD maps, this is putting us in a bind.
Hello RowCropAg,
Thank you for posting on the Intel
To have a better understanding of the situation, please answer the following questions:
- Take a screenshot for CPU usage while app is running.
- Download, run, save and attach the report for the following tool Intel® System Support Utility for Windows (SSU), you can find the steps on the link How to get the Intel® System Support Utility Logs on Windows.
Andres P.
Hello RowCropAg,
Andres P.
Hello RowCropAg,
Andres P.
I encountered almost the same problem. I have a processor on a laptop i9-13900H. When I deploy my application locally in Visual Studio, the speed of launching a Web project is no different either in normal mode or in Intel-boost mode, and what’s more sad is that on my old laptop with an older generation Ryzen everything worked many times faster. If there are any steps to improve this case I would be glad to listen
Sorry for my English, I used a translator to improve the text. Processor i9-1300hx. I can send you a report
Could you please contact me to see if the problem has been resolved? I'm having the same problem with the same software on the same system. (DJI Terra)
<Email removed>
