17151 Discussions
is S2600CP motherboard compatible with E5-2696v2?
jps
I went accross 2x E5-2696v2 processors and tried to use them in one of our work stations based on S2600CP or S2600CP4 motherboards. Unfortunately neither of the computers worked with those CPU's. Both of the computers worked fine with 2690 v1 and 2667 v2 though. So my question is: should the two platforms work with E5-2696v2 processors?
more specific information about platforms:
Chipset: Intel C602 rev. 06
Mainboard Model: S2600CP (0x000001AE - 0x005368B0)
revision: E99552-510
serial: QSCP34300402
BIOS: SE5C600.86B.02.02.0002.122320131210 dated at 12/23/2013
where minimum required bios is ver. 02.01.0002 from 09/07/2013
the list of compatible processors is: http://www.intel.com/support/motherboards/server/sb/CS-033241.htm http://www.intel.com/support/motherboards/server/sb/CS-033241.htm
where 2696v2 does no appear.
looking forward your help.
regards
janusz
Allan_J_Intel1
Please continue working here:
Allan.
Allan_J_Intel1
Allan.
