17151 Discussions
larggest supported HDD size for P4 3.20GHz?
Hi ! I need some help. I have an older desktop setup that still runs great, but I'd like to add a new internal HDD. I have an open SATA port on my MB, so I went to my local PC shop & was told that my processor would limit adding a second internal HDD over 160GB. They said that anything over that would require a new processor (and hence a new motherboard, etc). Sounded like the guy was just trying to make a sale on my upgrading, so thought I would ask here first.
Here is my setup:
P3 3.20GHz 800MHz 512KB cache
3 GB RAM
MB= Asus P4P800-E Deluxe (ATX/Socket478/865PE)
ATI all-in-wonder RADEON 9800Pro
160GB 7200rpm HDD
running Windows 7 Pro
Like I said, the system works great for what I use it for, so not looking to upgrade anything. I have 2 TB on an external HDD (usb), but don't like to leave that running 24-7, as its for backup only. The MC has an open SATA slot & the case has an open drive bay, so I'm looking to add a second internal HDD (up to 1.5 TB if I can). Being slightly suspicious of the story from the local PC shop, but not PC-keen enough to know for myself, I'd just like to know what maximum size secondary internal HDD I can use with my setup.
Thanks for the help !!!
Hi the CPU will definitely NOT limit the size of the HDD.
The chipset of your motherboard could limit it.
Thanks for the reply. Good to know the processor doesnt limit the HDD size, but I guess now I need to run over to the Asus site to check on the MB chipset !
Thanks again !
