16964 Discussions
low frequency velocity CPU
SCase
hi everyone, two days ago i bought my pc and all the time the velocity of the CPU its 1.2 GHz but its a intel i7.7820X 3.6 GHz up to 4.5. I add screenshots of programs to see moe information, i try overclock, reset de bios and a los tof things i don't know what to do, some can help me please?¿?¿
Hello alloyq,
I understand that you want to inquire on the low frequency that your Intel® Core™ i7-7820X X-series Processor is displaying.
In order for me to assist you better, please provide me with the .txt file that the System Support Utility will generate. To attach a file, you must click the "Attach" option on the bottom right-hand corner of the response box.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
As you may know the base frequency for this device starts at 3.60 GHz and cab be increased automatically by the system to 4.30 GHz.
These values may change due to the fact that this is a dynamic feature that will increase or decrease depending on the task that you perform and the resources consumed by the system in that moment. The fact that the processor is showing up a frequency of 1.2 GHz captured our attention, however we do not think that it is a sign of a defective CPU.
However we would like you to get in touch with your motherboard manufacturer, and check for BIOS updates, is the BIOS is not up to date, it may affect the readings of the values on the CPU.
I hope to hear from you soon, please let us know the outcome.
Diego S.
SCase
this its the file
Hello alloyq,
Thank you for your response.
In this case a reason for CPU not running on stock speeds could be an actual energy save feature on the actual OS or board.
I strongly recommend checking the power plans of your OS since somehow it could be set up to "Low" performance as a default, something that you can actually change to "Max" performance through the power plan settings of your OS.
For more information please take a look to this Microsoft* forum:
https://docs.microsoft.com/en-us/windows-hardware/design/device-experiences/advanced-power-settings https://docs.microsoft.com/en-us/windows-hardware/design/device-experiences/advanced-power-settings
I can totally assure that based on your report, your system is totally fine, however if you want to make sure that everything is set up properly at a OS level please go ahead and review the settings from your power plan.
As shared before we would like you to get in touch with your motherboard manufacturer, and check for BIOS updates, is the BIOS is not up to date, it may affect the readings of the values on the CPU.
As well if you want to test your processor, please go ahead and perform a test through our Intel® Processor Diagnostic Tool that you can download here:
https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool
Let us know if any error message shows up.
I hope this helps.
Diego S.
Hello alloyq,
We just wanted to double check if you need further help.
Please do not hesitate on replying back if you need more assistance.
Diego S.
