17153 Discussions
pc hp 23-r101la/ procesador i3 4170t
MRami2
Tengo un PC HP r101la equipado con un procesador I3 4170T cpu 3.2 ghz¿ necesito saber si puedo instalar un procesador Intel mas potente?, si es posible. agradeceré me indiquen que procesadores puedo usar y si es necesario efectuar algún cambio de placa base u otro componente.
De antemano gracias
Not applicable
Hi Miguel66,
It is possible to upgrade the processor on your system; however, only Hewlett Packard knows which processors are supported by the BIOS of the motherboard.
I am sending you compatible processors with the same socket type of the Intel® Core™ i3-4170t, filter by Desktop.
http://ark.intel.com/products/codename/42174/Haswell# @Desktop Products (Formerly Haswell)
Take in consideration the wattage of your power supply and air flow inside your case.
Mike C
