performence issues
AMcGr1
hello, first post to the boards! i have a mid high range computer, Intel Core i7-3770K processor, ASRock Z77 Extreme4 motherboard, 7990 Hd saphire readon 3gbgddr5, 16 gigs of ram, windows 8.1. corsair h80 hydro pump with fan in and out. 8 fans... the problem is ill try to run any game from need for speed rivals to diablo 3 and the computer will get really hot, like around 105c or even running avg. i used the optimizer from avg to clean it up and optimize but it didnt really do anything for actual performance. any sugestions :?
Silvia_L_Intel1
I would recommend you to test the system out of the chassis using minimal configuration. Please use the onboard video.
Check with the motherboard manufacture if they have a new BIOS available.
Then, start adding one component at the time until you find the conflicting one.
Switch components to narrow the issue if possible.
Make sure you are using correct memory specifications; this processor supports DDR3 1333/1600 MHz 1.5V. http://ark.intel.com/products/65523/Intel-Core-i7-3770K-Processor-8M-Cache-up-to-3_90-GHz?q=%20i7-3770K http://ark.intel.com/products/65523/Intel-Core-i7-3770K-Processor-8M-Cache-up-to-3_90-GHz?q=%20i7-3770K
