17161 Discussions
wat is de snelste processor die ik in mijn moederbord kan plaatsen?
wat is de snelste processor die ik in de Intel Mobile HM57 moederbord kan plaatsen?
AlHill
It depends on what the BIOS of the board supports.
Provide your motherboard manufacturer and model number.
Doc
Mijn moeder bord is een Intel Mobile HM57
Mijn type laptop is een HP ProBook 4520s
En mijn fabrikant zoals hierboven te zien HP
AlHill
You could have a problem.
Here are the processors supported on your laptop:
Look under "product features" here: http://h20564.www2.hp.com/hpsc/doc/public/display?docId=emr_na-c02057765# N10049 HP Support document - HP Support Center
Now for the problem. These processors come in two socket versions: either they are soldered to the board, or not.
If they are soldered to the board, you cannot upgrade anything.
If they are not soldered, then it may be possible.
I have chosen the two fastest for comparison. Look under "package specifications" here: http://ark.intel.com/compare/43544,43560 Intel® Product Specification Comparison
The BGA socket means the processor is soldered to the board and cannot be changed.
So, you need to determine what socket you have before you can go forward.
Any upgrade processor must be socket, BIOS, and chipset compatible. Only the manufacturer (HP) can tell you what their bios supports.
In my opinion, with a laptop this old, you would do better to replace the laptop with a new or newer model.
Doc
kan de Intel Core i5-2450M processor 2.5 Ghz Socket FCBGA1023, PPGA988 er ook in?
de oude i3 die erin zit is niet gesoldeerd
AlHill
It is highly unlikely that you could use the i5-2450m.
In any case, contact HP to determine what processors their BIOS supports.
Doc
Thank you, Al Hill for the information you provided.
Leon., As Al mentioned, the best source for you to get compatibility information is the manufacturer since you have to consider the socket of the mainboard and also the BIOS compatibility.
Please don't hesitate in contacting us back if you need further assistance.
JC
