12603 Discussions
想要NIOS 硬體跟軟體 燒死再FPGA裡面 到最後一步的時候,出現了ERROR。
RWeiz
Error: No EPCS layout data - looking for section [EPCS-9D6017]
Error: Unable to use EPCS device
Error: Error code: 8 for command: nios2-flash-programmer "D:/ANSER_Proj/Altera_FPGA/TIJ_Engine_proj/software/TIJ_bsp/flash/DE10_NANO_TIJ_Engine_epcs_flash_controller_0.flash" --base=0x41000 --epcs --sidp=0x42138 --id=0x42138 --timestamp=1555660140 --device=2 --instance=0 '--cable=DE-SoC on localhost [USB-1]' --program --verbose
使用的板子
DE0_NANO
https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=Taiwan&No=1047
使用的軟體
​Quartus (Quartus Prime 18.1) Lite Edition
Ahmed_H_Intel1
Hello, Can you please use the (.jic) JTAG Indirect Configuration procedure instead of the NIOS II flash programmer? I will attach the step by step guide to tell you how to use the (jic) procedure. The NIOS II flash programmer I never recommend.
Ahmed_H_Intel1
Attached is the step by step guide of how to use the JIC programming procedure
Please follow this to get the issue resolved.
If you still insist to use the NIOS II flash programme, I suggest the following solution:
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd03212006_29.html?GSA_pos=591&WT.oss_r=1&WT.oss=io
RWeiz
我的JIC可以燒錄成功​,因為之後設備不會連接在電腦上,C的程式必需要燒錄到FPGA上
Ahmed_H_Intel1
Hi Ren, Here is the translation of your comment (My JIC can be burned successfully, because the device will not be connected to the computer afterwards, and the C program must be burned to the FPGA.) Do you mean that the error is gone? if not please explain more. Regards,
