12748 Discussions
16-bit shift left 2 register in VHDL
Ok, so I have a shift register (code below). But I need a shift left 2 register. So would I simply put "reg <= reg (14 downto 0) & '0' & '0';" ? Or do I need to do the shift process twice? I need help ASAP...any help would be great.
entity shiftreg is
Port
en : in STD_LOGIC;
clock : in STD_LOGIC;
reset :in std_logic;
data_i : in STD_LOGIC_VECTOR (15 downto 0);
shift : in STD_LOGIC;
data_o : out STD_LOGIC
end shiftreg;
architecture Behavioral of shiftreg is
signal reg: std_logic_vector (15 downto 0);
begin
process (clock, en,reg,reset)
begin
if reset<='1' then
reg<=data_i;
elsif (clock'event and clock <='1' ) then
if (en <='1') then
reg <= data_i;
elsif (en<='1' and shift<='1') then
reg <= reg (14 downto 0) & '0';
end if;
end if;
end process;
data_o <= reg (15);
end Behavioral;
"reg <= reg (14 downto 0) & '0' & '0' wont work because you're trying to assign 17 bits to a 16 bit vector. "reg <= reg (13 downto 0) & '0' & '0'" would work.
Also, you have put <= in all the if conditions when you just mean =
Multiply by 2 gives the result of left shift by 2......
multiply by 2 gives left shift by 1. But multiplication isnt appropriate, because he has no numerical values.
--- Quote Start ---
--- Quote End ---
she.
Thanks! I got it working...just changed it to (13 downto 0).
