8051 bus bridge
in the first NIOS releases, Altera had a free avalon slave core, to connect 805x peripherals to the avalon bus (data/address multiplex 8 bit). This core is no longer avaiable.
Does anyone have this core in his arichve or an similar core ?
Andreas
--- Quote Start ---
originally posted by micromaster@Oct 27 2006, 12:58 PM
hi,
in the first nios releases, altera had a free avalon slave core, to connect 805x peripherals to the avalon bus (data/address multiplex 8 bit). this core is no longer avaiable.
does anyone have this core in his arichve or an similar core ?
andreas
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18954)
--- quote end ---
--- Quote End ---
Hello Micromaster,
Its long ago since you posted. I&#39;ve had the same search. Finaly I wrote my own core to connect to an 805x peripheral. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
If you still need this core, pls contact me
Regards Bailand
hi Bailand,
I know a long time has passed,
but is there any chance getting this core?
David
