12603 Discussions
A new problem when uses the ftp service by inetd
<<<<My English is not good, please forgives.>>>>
When a ftp user will connect the server, inetd then
starts a ftpd process, but when the ftp user will disconnect,
the ftpd process did not end.
=============================================================# ps
PID PORT STAT SIZE SHARED %CPU COMMAND
23 S 139K 0K 0.0 /bin/dhcpcd -NRY
24 S 95K 0K 0.0 /bin/inetd
25 S 279K 0K 0.0 /bin/boa -c /mnt/cf/httpd/
26 S 195K 0K 0.0 /bin/sh
30 S 287K 0K 0.0 /bin/ftpd
34 S 287K 0K 0.0 /bin/ftpd
41 S 287K 0K 0.0 /bin/ftpd
47 R 83K 0K 0.0 ps
now there is 3 ftpd process, but in fact was i has connected thrice , not three users connects.
why??
thx.
You&#39;re right, at the end of the main function, the ftp server goes into an infinite loop looking for commands to parse but it doesn&#39;t check for a closed socket.
As quirky as it sounds, you need to send a "quit" command at the end of your session in order for the ftp server to shut down.
thx for your reply,
But i cannot guarantee each people all send "quit" at the end of the session.
After I modify the code ( i add a "exit(0);" in the ftpcmd.c after send "bye" to client),
using the FlashFXP software not to have the question,
but using the IE not to be good.
I cant qualify the user to use a software to link the ftp service.
