12600 Discussions
A problem in (Nios II eclipe)WH menu
I'm a new for FPGA desgin and I have a problem in NiosII. When I go to (Run as), I can't find ( NiosII instruction set simulator ), (Run as) contains only (1 local c/c++ application & Run configuration). Please help me.
Did you follow a "getting started" guide ?
Which Nios II IDE version are you using ?
You may mean that you can't find "Run as NiosII Hardware..."
Do you right-click on your project to do "Run as" or do you "run as" through top menu ?
In order to run a Nios II on a board, you must first configure the board :
* by downloading to the FPGA the correct .sof
* by using "factory config" (or others but one with Nios II CPU) if you are using an Altera development kit
If you are writing your custom software, have you built a BSP (if you are using Qsys or "system library" if you are using SOPC)
Thank you 'mmTsuchi' for quick reply,
1-yes
2- Nios II 11.1 Software for Eclipse
3-No, I don't have any board, so I want to do my work using simulator
4-I do right-click on my project to do "Run as".
5- I am using SOPC and I have built a BSP.
I did all you have mentioned.
Instead of "run as", go to "run..."
