Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
A problem of programming flash...
Hi all,
I meet a new problem when programming flash
in NiosII IDE.
Just because the err popped during regeneration,
I removed the epcs_controller from the components
list of my design in the SOPCBuilder.Then I regenerated
the actual design,it proved successful.After this,
I updated the symbol in the .bdf and recompiled.After
the compilation,I builded a new project "hello_led" from
the template projects list in the NiosII IDE.
It seemed that building and later running as NiosII Hardware
either was OK.
However,when I tried to program this project into the
flash on the dev board,some err message came out,
-----------------------# ! /bin/sh# # This file was automatically generated by the Nios II IDE Flash Programmer.# # It will be overwritten when the flash programmer options change.#
cd E:/EDA/UP3/design/The_Last_One/software/hello_led_1/Debug
# Creating .flash file for the FPGA configuration
$SOPC_KIT_NIOS2/bin/sof2flash --flash=U8 --offset=0x700000 --input=E:/EDA/UP3/de
sign/The_Last_One/For_UP3.sof --output=For_UP3.flash
Info: *******************************************************************
Info: Running Quartus II Convert_programming_file
Info: Command: quartus_cpf --no_banner --convert E:/EDA/UP3/design/The_Last_One/
For_UP3.sof For_UP3.rbf
Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings
Info: Processing ended: Wed Jul 27 18:11:52 2005
Info: Elapsed time: 00:00:01
WARNING: Default charset GBK not supported, using ISO-8859-1 instead
# Programming flash with the FPGA configuration
$SOPC_KIT_NIOS2/bin/nios2-flash-programmer --input=For_UP3.flash --sof=E:/EDA/UP
3/design/The_Last_One/my_new_board/system/my_new_board.sof --base=0x00200000
Jul 27, 2005 6:11:53 PM - (??) nios2-flash-programmer: Launching Quartus Program
mer to download:
E:/EDA/UP3/design/The_Last_One/my_new_board/system/my_new_board.sof
Unable to synchronize with target.
Jul 27, 2005 6:13:01 PM - (??) nios2-flash-programmer: Error opening target hard
ware
In order to program flash, you must first create a purpose-built
flash-programming design (i.e. FPGA configuration) and associate it with
your particular board. The Nios development kit is delivered with purpose-bui
lt
flash-programming designs pre-built for several development boards. If you wi
sh
to program flash on your own board, you must first create a flash-programming
design.
The process of creating a flash-programming design for your board is mostly
automated. From a bash-shell, execute this script:
mk_target_board --help
The help-message includes references to other documentation on programming
flash and targeting Nios systems to custom board designs.
- exiting.
# Creating .flash file for the project
$SOPC_KIT_NIOS2/bin/elf2flash --flash=U8 --base=0x00800000 --end=0x8fffff --rese
t=0xa00000 --input=hello_led_1.elf --output=flash.flash --boot=$SOPC_KIT_NIOS2/c
omponents/altera_nios2/boot_loader_cfi.srec
# Programming flash with the project
$SOPC_KIT_NIOS2/bin/nios2-flash-programmer --input=flash.flash --sof=__NO_SOF_PL
EASE__ --base=0x00200000
Jul 27, 2005 6:13:03 PM - (??) nios2-flash-programmer: Input file empty--no data
to program into flash. Exiting.
I notice "nios2-flash-programmer: Input file empty--no data
to program into flash. Exiting" in the message above.
But I cannot figure out why,because I successflly
made my target board and builded the "hello_led"
project.So I wonder whether this problem might be has
somthing with my removing of the epcs_controller.
Could you please give some suggestions about that?
Thank you in advance!
Don
ps.I use the mux module provided by SLS to the NiosII
module running on the board.So I only make
a LCD_RW _N signal as hign level to disable its
sharing of the tri-state bus.(Because the SRAM shares
the same Read signal as the flash on the board,and the
SDRAM has not a read signal. )
Highlighted
Re: A problem of programming flash...
After these days&#39; work,I still cannot resolve this problem, http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
could anyone give me some suggestions?
Many thanks to you!
Highlighted
Hi Don,
Is For_UP3.sof your flash programming design, or your normal system design?
--Scott
Highlighted
Thanks Scott!
That&#39;s right,For_UP3 is the top entity of my design,and the .sof
file is For_UP3.sof,could you give me some suggestions please?
Highlighted
I wonder is there something with the EPCS controller?
Highlighted
Hi Don,
I don&#39;t have a UP3 board ... but as I recall, it only has 2MB of flash. Soooo ...
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
sign/The_Last_One/For_UP3.sof --output=For_UP3.flash[/b]
--- Quote End ---
--- Quote Start ---
3/design/The_Last_One/my_new_board/system/my_new_board.sof --base=0x00200000[/b]
--- Quote End ---
doesn&#39;t appear correct -- specifically the offset.
Did you use mk_target_board to create the flash programmer design my_new_board.sof?
--Scott
Highlighted
Now I could see the flash programmer in the NiosII IDE
indeed work,because I see something like this while programming:
Pre-Reading 85KBytes of data from U15:
********************* (31.454 sec).
Aug 2, 2005 6:51:09 PM - (??) nios2-flash-programmer: Success. Zero
bytes writt
en to U15-
(because device matched contents of For_UP3.flash)
Aug 2, 2005 6:51:09 PM - (??) nios2-flash-programmer: Flash
programming complete
However,there comes out some new message
after above like this::
Aug 2, 2005 6:51:10 PM - (??) nios2-flash-programmer:
Aug 2, 2005 6:51:11 PM - (??) nios2-flash-programmer
: SOF-download skipped.
Aug 2, 2005 6:51:14 PM - (??) nios2-flash-programmer
: Flash file is too large to
fit in flash memory
But at then what the design I wanted to program into
the Flash is a "Hello_World" project template,perhaps
the smallest design of all.
So how could this file be so large that cannot be
programmed into the Flash chip,whose size is 2M ?
Besides,I tried to program some other template
projects into the Flash chip,but the message
were all the same as above indicating they were
too large to program.
Could anyone tell me why this happen?
Thanks in advance!
Don
Highlighted
Hi Don,
Because _now_ you&#39;re writing into U15, which is an EPCS1 device which has a
128 KB capacity (split between the configuration data and your app) -- not U8
which is the parallel flash device (2 MB).
Don, if want to find a solution, you shouldn&#39;t keep changing the problem ;-)
Good Luck,
--Scott
Highlighted
Thanks Scott!
Sorry, I really didnot mean to keep changing my problem . http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif
I got the solution of the first post from Altera&#39;s mysupport,
and then I made a new target board aimed at programming
the epcs_controller.But as you see,the new problem I met
is due to the limited size of the EPCS chip. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
From your suggestions, I &#39;m gonna make another target board
aimed at programming the flash instead of the epcs_controller,
and I think I should set the reset address of the system to Flash(0x0000),
do you think would that work?
Many thanks:)
Don
