Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
AN458 Alternative Nios II Boot Methods doesn't work with Quartus Lite toolsuite
Hi
I would like to share what I have experienced with AN458.
It used to work with the older Quartus versions, but since Quartus Lite it doesn't work any more.
I don't know the exact reason but make_flash_image_script.sh file must be modified: this code section must be commented:
conv -d $fake_copier ;
# check for errors
if [ $? -ne 0 ] ; then
echo ""
echo "error: trying to convert the file $fake_copier to dos format."
echo ""
echo "deleting file $fake_copier, and $tmp0_outfile_elf and exiting!"
echo ""
rm -f $fake_copier;
rm -f $tmp0_outfile_elf;
exit 1;
fi
it used to transform the LF (Line Feed) into CR LF (Carriage Return + Line Feed)
