Hi all,
I am trying to debug a simple hello world user space level application on an ARM board running a custom flavor of Linux. Gdbserver has been installed on the board, and the RSE is able to connect successfully and browse the filesystem. I have created a new debug configuration ( DS-5 Debugger -> Altera -> Cyclone V SOC (Dual Core) -> Linux Application Debug -> Download and debug application ), pointing to my RSE connection. When I try to start the debug, I get the following message: Unable to connect to New_configuration Reason: Failed to connect to the device Invalid host. The hostid of this system does not match the hostid specified in the license file Feature: altera_ds_debugger_gdbserver Hostid: [host id] The host Id printed in the message is the correct host id for my development machine, not the target ARM machine I am trying to debug the code on. Does anyone see anything immediately wrong with what I am doing? Thanks, NickLink Copied
By the way, is this an hello world example from one of the design guide?
your file system store in the SD card? that with a SSH connection enabled? .
I have a very strong feeling this is some thing to do wit your license, as the fasted test, simply just debug a hello world example.. see if this error still happens,
