12604 Discussions
Accessing inputs and outputs of a custom component
Hello every body;
I have created my custom compnent caled "cipher", it takes 2x128 bits input and produce one 128bit ouput, the component definition in system.h is:
#define ALT_MODULE_CLASS_Cipher_0 Cipher
#define CIPHER_0_BASE 0x201020
#define CIPHER_0_IRQ -1
#define CIPHER_0_IRQ_INTERRUPT_CONTROLLER_ID -1
#define CIPHER_0_NAME "/dev/Cipher_0"
#define CIPHER_0_SPAN 32
#define CIPHER_0_TYPE "Cipher"
My Quistions are:
1-what is the address of the inputs and outputs.
2-how can i access them if i want to pass and read the inputs and the outputs as 4x4 array.
--- Quote Start ---
--- Quote End ---
CIPHER_0_BASE + offset
where 'offset' is whatever register addresses you have defined within your custom component (i.e. how you decode the 'address' on the Avalon-MM Slave port)
--- Quote Start ---
--- Quote End ---
You can use IORD/IOWR macros to access the registers you have created one at a time.
Thanks Ted for your reply>
but I have an address span of 32 byte or (16 byte for each input), here what is the base address of the output ?
You need to take care of address in your custom component.Address will be as shown in below code.
//RTL Code for write logic
case({av_write,av_address[4:0]})
6'b1_00000 cipher_in1[31:0] <= av_wrdata;
6'b1_00100 cipher_in1[63:32] <= av_wrdata;
6'b1_01000 cipher_in1[95:64] <= av_wrdata;
6'b1_01100 cipher_in1[127:96] <= av_wrdata;
6'b1_10000 cipher_in2[31:0] <= av_wrdata;
6'b1_10100 cipher_in2[63:32] <= av_wrdata;
6'b1_11000 cipher_in2[95:64] <= av_wrdata;
6'b1_11100 cipher_in2[127:96] <= av_wrdata;
endcase
//RTL code for read logic
case(av_address)
0 : av_rddata <= cipher_out[31:0];
4 : av_rddata <= cipher_out[63:32];
8 : av_rddata <= cipher_out[95:64];
12 : av_rddata <= cipher_out[127:96];
endcase
//NIOS Code
//Cipher Input 1
IOWR(CIPHER_0_BASE,0x00,0x03020100);
IOWR(CIPHER_0_BASE,0x04,0x07060504);
IOWR(CIPHER_0_BASE,0x08,0x0b0a0908);
IOWR(CIPHER_0_BASE,0x0c,0x0f0e0d0c);
//Cipher Input 2
IOWR(CIPHER_0_BASE,0x10,0x03020100);
IOWR(CIPHER_0_BASE,0x14,0x07060504);
IOWR(CIPHER_0_BASE,0x18,0x0b0a0908);
IOWR(CIPHER_0_BASE,0x1c,0x0f0e0d0c);
--- Quote Start ---
--- Quote End ---
You would need to review the custom component (Verilog/VHDL) you created and understand what address is supplied to it in order to read the 'output'.
It sounds like maybe you havent declared a wide enough address space to fit (3) 128-bit elements?
Thanks ted for your attentions;
I tried what you have illustrated and worked well with me, now, my custom logic takes 26 clk cycles to produce the output, how can i access the output just it finish processing the inputs.
