12603 Discussions
Accessing memory sections from software.
Is there a way to access the beginning and end of the memory sections from within the software? For example, I need to know where the .text section begins and ends so that I can calculate a checksum but I don't want to hardcode it.
I am not sure if you are looking for this but please take a look into .objdump file generated in the software folder (same directory with .elf file).
Right, I'm aware of the .objdump file. What I'm wanting is something that will give me the beginning/end addresses of sections while I'm still working on the code. Until I'm finished coding and testing, I really don't want to hardcode it and change it every time I add or take away code.
I see. I am not aware of such feature available.
